454 international hydraulic lift problems
JamesT
08-27-2007 12:12:18
Original problem: 3pt lift arms raised and then would not come back down. I took it to have it worked on and now the arms will only raise with the draft control not the lift control. I know this is not correct and it causes the arms to either be in the fully raised or lowered position (no in between). The gentleman that worked on it is perplexed as to what to do now.
Any help would be appreciated.
Diesel Bob
08-27-2007 13:36:03
 Re: 454 international hydraulic lift problems in reply to JamesT, 08-27-2007 12:12:18
It sound like a problem with the draft control valve located inside the hydraulic top cover there is a small inspection on the top this can be removed and if you no what to look for you maybe able to get an idea of what is wrong just be carefull in there
jamest
08-28-2007 06:42:23
 Re: 454 international hydraulic lift problems in reply to Diesel Bob, 08-27-2007 13:36:03
What should I look for?
Diesel Bob
08-30-2007 13:32:06
 Re: 454 international hydraulic lift problems in reply to jamest, 08-28-2007 06:42:23
Is there any linkage that has fallen off or can you tell if the draft control valve centre spool is stuck out also something completely diffferent could be that the external lift linkage maybe on back to front
