DT436 international engine
J Murphy
08-27-2007 14:43:52
I have a 986 International with what I think is a DT436. The numbers came off the intake manifold. Is this possible.
J Murphy
08-28-2007 14:24:09
 Re: DT436 international engine in reply to J Murphy, 08-27-2007 14:43:52
What I was told is a 986 didn't come with a turbo but this tractor has one. I just bought this tractor and never had a IH before had some old Farmall's but not a IH. I had the injector pump overhaled (it was bad when I got it) the person asked if this tractor had a turbo when I told him yes he said that the pump needed to be turned up 20%. If so what is the HP on the tractor.
Larry NCKS
08-28-2007 05:16:05
 Re: DT436 international engine in reply to F-Dean, 08-27-2007 14:43:52
Yes sir, the 966 had a D414, but this post is about a 986, which was sent from the factory with a D436. I had one of the first 986s in my part of the world.
Larry NCKS
08-27-2007 18:41:15
 Re: DT436 international engine in reply to El Toro, 08-27-2007 14:43:52
It is possible, but it didn't come out of the factory like that. Factory would have been a D436. If it has a DT it, or part of it as others have illuded to is a transplant.
El Toro
08-27-2007 17:07:29
If it has a turbo the engine may have been out of a 1466 tractor. Hal
ejr-IA.
08-27-2007 14:53:24
That is what they put in them from the factory 105 pto hp.none turbo.
El Toro
08-27-2007 14:50:26
They used the D436 engine in those tractors. Hal
Allan In NE
08-27-2007 14:52:30
 Re: DT436 international engine in reply to El Toro, 08-27-2007 14:50:26
Think he's refering to the "turbo" initial, Hal.
Allan
El Toro
08-27-2007 15:15:21
 Re: DT436 international engine in reply to Allan In NE, 08-27-2007 14:52:30
I knew that. Hal
Allan In NE
08-27-2007 15:21:36
 Re: DT436 international engine in reply to El Toro, 08-27-2007 15:15:21
I've never owned one. Did they all come with the "DT" designation?
Allan
Owen Aaland
08-28-2007 08:10:34
 Re: DT436 international engine in reply to Allan In NE, 08-27-2007 15:21:36
Turboed tractor engines should have DTT as model number.
El Toro
08-27-2007 15:40:37
That manifold may have been changed or like Chrysler products back in the 50's when they ran out of parts near the end of the year you needed the model number and serial of the distributor since it could be Plymouth, DeSoto or Dodge.
Hal
the Unforgiven
08-27-2007 17:23:28
 Re: DT436 international engine in reply to El Toro, 08-27-2007 15:40:37
My 186 Hydro had a DT436, no exhaust grinder.
wgatewood
08-27-2007 18:56:03
 Re: DT436 international engine in reply to the Unforgiven, 08-27-2007 17:23:28
the 966 was sent from the factory with a d-414 enging in them
