super 'C ' HYD Woos'
Larry in GA.
08-27-2007 17:56:24
Thanks for the help earlier and you are right Brad Marshall Is a great help but we are still having a problem coming up with a good drive shaft for a 355007R92 pump. Brad is still looking and I appreciate the time he is spending. But I was wondering did I read on here that there is a speedy sleeve available for this shaft? Or does someone out there have a good shaft?
Thanks
Larry
El Toro
08-28-2007 05:50:24
 Re: super 'C ' HYD Woos' in reply to Larry in GA., 08-27-2007 17:56:24
third party image
Is your pump like this breakdown? Hal
El Toro
08-28-2007 05:39:18
I think Case/IH has the speedi-sleeves for $16.00
part # 378193R91. Hal
CityBoy-McCoy
08-27-2007 18:49:38
 Re: Woes in reply to Larry in GA., 08-27-2007 17:56:24
There are ready (or speedy) sleeves available for nearly any size shaft which accepts a bearing and/or seal. Using a good set of calipers, try to measure an area of the surface with no wear. A good bearing shop should be able to take it from there.....
mike
georgeky
08-27-2007 18:35:01
I think there is a speedy sleeve for those. I have a pump if you can't get anything going. Suprised that Email me if you want.
