130 compression ck
Tommy in NC
08-28-2007 09:08:18
what range should the compression be on the pistons for a 130?
scotty
08-28-2007 09:35:12
 Re: 130 compression ck in reply to Tommy in NC, 08-28-2007 09:08:18
Afternoon Tommy, Well 125 psi would be ideal but you can run the tractor with significantly less. I would think that much less than 90 psi and your going to be losing some power ! Some guys are running their tractors on 70 psi and still getting some work done !
scotty
Tommy in NC
08-28-2007 10:10:27
 Re: 130 compression ck in reply to scotty, 08-28-2007 09:35:12
thanks for reply Scotty,I am getting about 85 to 90 on three of them and 55 on one
scotty
08-28-2007 11:37:20
 Re: 130 compression ck in reply to Tommy in NC, 08-28-2007 10:10:27
Tommy, 55 psi is quite low. How does the plug look in that cylinder ? If its fouling its time to tear into the engine.
