Farmall 400 diesel head gasket
FarmallRick
08-29-2007 19:52:15
How do I know that I have a bad head gasket? I have the head off the tractor and the old gasket in my hand. What do I look for?
Allan In NE
08-30-2007 04:30:15
 Re: Farmall 400 diesel head gasket in reply to FarmallRick, 08-29-2007 19:52:15
If it's bad, you'll see it. :>)
Allan
third party image
georgeky
08-30-2007 05:53:01
 Re: Farmall 400 diesel head gasket in reply to Allan In NE, 08-30-2007 04:30:15
Allan, that one sure burnt up.
georgeky
08-29-2007 21:05:25
You can reuse those gaskets sometimes. Is it is metal on both sides? Paint it with aluminum paint and wait for it to dry enough that the hair on the back of your hand don't stick to it and put it on and torque the head down. Those gaskets are over 150.00 bucks. Why did you take it off? If you had water in the oil it likely is bad or something is cracked.
Andy Motteberg
08-29-2007 19:56:57
If you have removed the head gasket, you MUST replace it, you cannot re-use a head gasket. Get one from a parts store or the IH dealer.
Owen Aaland
08-30-2007 06:54:08
 Re: Farmall 400 diesel head gasket in reply to Andy Motteberg, 08-29-2007 19:56:57
You will not get much arguement about never reusing a head gasket being the best course to follow, but many of us have reused them with no problems. One reason to be carefull how you take this old iron apart is you never know when you may have to reuse something.
I have even gone so far as to take two blown out gaskets and use the best part of each to splice together to make a usable gasket. That was on a Wisconsin V4 on a pea combine. That engine ran 18 hours a day for more than a week before it was replaced with a new one.
