int. t340 dozer
mark or larry
08-31-2007 05:24:56
We have a int. t340 dozer with a d166 diesel engine that is all new with a new head springs and valves and the injector pump and injectors and glow plugs all cylinders have 200 to 210 lbs of comp. the motor and injector pump are in perfect timeing but it still wont run. It will fire up for about 4 seconds and die but will run a little longer if you hold the glow plug button down but it still dont sound like it should. We need help bad we are about to go crazy please call or email if you can heip. Thank you 979-229-6807 Larry
Tractor Tom
08-31-2007 06:45:04
 Re: int. t340 dozer in reply to mark or larry, 08-31-2007 05:24:56
Wish I could help you but let me suggest you pose your question on the crawler, loaders, ect. forum here at YTmag, or, better yet, over at Redpower. They have a lot of folks that seem to really know IH crawlers;
http://www.redpowermagazine.com/forums/index.php?showforum=9
