international 2424
simon bollin
08-31-2007 10:40:03
3 point arms not going up or down on tractor,just got tractor any ideas?
simon bollin
08-31-2007 19:21:05
 Re: international 2424 in reply to simon bollin, 08-31-2007 10:40:03
they are down now
simon bollin
09-01-2007 13:12:54
 Re: international 2424 in reply to simon bollin, 08-31-2007 19:21:05
thank you guys the selector valve was stuck fixed that now it goes up and down thank you
georgeky
08-31-2007 19:46:49
Yuo might have a loose linkage. I assume it has power steering, since it is an industrial model. It may also be that selector that 2444 is talking about. When it is one position the lift works. The other is for a remote cylinder. try switching it and see if your lift will work. right between your legs and on the right just a bit.
georgeky
08-31-2007 11:14:09
What position are they in now?
IH2444
08-31-2007 11:08:48
There is an isolator valve under the front of the seat. It might be shut off.
I am assuming you have fluid in the lift box and the pump works, etc...
