best way to strip paint
Pat-CT
09-01-2007 11:33:41
ok whats the best way to stip paint on a farmall H i have been using a little paint remover and rust remover wheel from napa but it takes me about an hour to do the pto cover and i have to do the rest of the tractor minus the sheet metal so whats the best way to strip it without buying a 500 bead blaster or something
Hoss in Maine
09-01-2007 14:00:17
 Re: best way to strip paint in reply to Pat-CT, 09-01-2007 11:33:41
I use just a wire wheel on a small disc grinder.41/2in and face shield ,no heat nostripper,works great. Later Hoss
Pat-CT
09-01-2007 13:46:39
how would i use this lye solution or the oven cleaner i dont have access to an oxy accetaline torch so thats no good thanks for your time
SuperA-Tx
09-01-2007 18:50:04
 Re: best way to strip paint in reply to Pat-CT, 09-01-2007 13:46:39
How would you use the oven cleaner?
Spray it on....take a break, 30 minutes or so.....wash it off....repeat if needed.
SuperA-Tx
09-01-2007 13:38:06
I used oven cleaner on a lot of the parts and then hit it with the sand blaster to clean it all up.
Had about 8 coats of paint on the fuel tank and I think it took two cans of cleaner.
Make sure you get all the oven cleaner off before you paint.
don g
09-01-2007 13:35:41
I used oven cleaner and a power washer and worked great. The only thing is you must keep the water on till it quits foaming.Someone on here said they had trouble later on and im quite sure it was because all the cleaner wasnt removed before the primer was applied.It does a wonderful job.
Dave H (MI)
09-01-2007 12:02:51
I use a lye solution with current (someone here can give you the recipe, mine is AWOL) to strip smaller pieces and I have heard of a lye gravy solution to do bigger part but have never used it. The first method has worked really well for me.
georgeky
09-01-2007 11:54:42
On all the cast iron, I use my torch. It bubbles up the old paint and then the wire wheel makes it look new. Wouldn't try it on sheet matal though. Sandblaster work too.
