Can you identify this?
Mike CA
09-01-2007 19:19:55
There is a hose port that has been added to the back of the top of the air cleaner tube. There is no hose attached to it, and I don't see where it could have gone. It looks like it's been welded into place, so I'm assuming it was a shade-tree addition.
Anyone have an idea for what purpose it was installed?
third party image
Andy Motteberg
09-02-2007 19:26:06
 Re: Can you identify this? in reply to Mike CA, 09-01-2007 19:19:55
That other end of that line goes into the valve cover. It is a air breather for the valve cover.
Andy.
dcw
09-01-2007 23:46:51
There is a hose that runs from there to the back of the cyl head.Then there is a tube that connects from one end of the head to the other under the valve cover,then another tube that connects to the top of the govenor housing.Its a breather line for the crankcase.It was missing from my H as well.
Yes,you should invest in some manuals.For the time being,you can go to the Case IH site and use the parts look up,and look up parts for your tractor.
Mike CA
09-02-2007 08:22:16
 Re: Can you identify this? in reply to dcw, 09-01-2007 23:46:51
dcw said: (quoted from post at 23:46:51 09/01/07) There is a hose that runs from there to the back of the cyl head.Then there is a tube that connects from one end of the head to the other under the valve cover,then another tube that connects to the top of the govenor housing.Its a breather line for the crankcase.It was missing from my H as well.
I did that, but it doesn't show a tube. Just a hole. Which is why I asked.
Mike CA
09-01-2007 19:34:19
CNKS said: Attaches to the head. Forerunner to the PCV valve.
In the parts manual it shows a hole. Nothing there, and nothing coming out. Where on the head should I look for the other end?
Athol Carr
09-01-2007 19:33:51
Should connect to breather pipe on rear eand of engine block, should then connect back of block via a pipe inside tappet cover to front of block then via pipe from front of block to vent on top of govenor housing.
CNKS
09-01-2007 19:32:03
Attaches to the head -- you need a parts manual. Forerunner to the PCV valve.
Curt in Minnesota
09-01-2007 19:31:11
Where did this tractor come from? From a more northernly climate? The only thing I could guess is that it is a ether injection port. Maybe they had a tube going back to the operator platform and it would be easier to start the thing with ether as you cranked the moter. My Dads 4020 and 3020 has a factory port under the steering wheel for this. However, this only a guess.
curt
jonnny2006
09-03-2007 03:27:59
 Re: Can you identify this? in reply to Curt in Minnesota, 09-01-2007 19:31:11
no curt it is not for starting fluid.....its a vent tube. made me laugh though!!!
Hoss in Maine
09-03-2007 08:22:55
 Re: Can you identify this? in reply to jonnny2006, 09-03-2007 03:27:59
Thats where ya hook up yer nitros so ya kin keep up with my jd-a,chuckle chuckle Later Hoss
