TA problems help
James3504
09-01-2007 19:36:32
I recently bought a 450. When you pull the TA, it works briefly and then you hear a spinning noise. Is it busted, worn out or out of adjustment. I'm new to TA's and know nothing about them. Any help would be great. I don't know how to adjust or determine what's wrong. Maybe some of you guy's could help me out with some info. Thanks!
flying belgian
09-01-2007 19:41:50
 Re: TA problems help in reply to James3504, 09-01-2007 19:36:32
It is wore out.
James3504
09-01-2007 19:43:45
 Re: TA problems help in reply to flying belgian, 09-01-2007 19:41:50
The ta clutch or the ramp gears and bearings or all of it?
Kevin Meier
09-01-2007 21:43:46
 Re: TA problems help in reply to James3504, 09-01-2007 19:43:45
Even if it is just the ta clutch i"d replace the entire ta while you"re there. I do have the parts if you are interested.
Kevin
MN Scott
09-01-2007 20:16:49
Most liklly the ramp/rollers in the one way clutch. But your going to have to tear it down and insepect everything or just run it the way it is with no TA.
