504 hydraulic line needed
bgoathill
09-01-2007 19:40:22
I blew a hydraulic line that goes from the valve back to the rear outlet. Part number 381134R91 is listed as a retired part and no longer available. I have tried several dealers and no luck. I'll probably try salvage yards next but I hate to put a used hydraulic hose on. Does anyone know if this hose was used on another model? Also, if you could point me to one, it would be much appreciated.
Weldon K
09-02-2007 18:43:29
 Re: 504 hydraulic line needed in reply to bgoathill, 09-01-2007 19:40:22
I have a 504 also and I am familiar with the line that you are referring to. I would have one made at a good full service hydraulic shop. There is one near me that can make it. They make and ship stuff nationwide. Perhaps I could help you get one made. E-mail me if interested.
bgoathill
09-02-2007 05:29:39
No, it's a hydraulic hose with an odd end on it, round with a bolt through it. It's leaking right at the end near the coupling so I can't splice it either.
MN Scott
09-01-2007 20:09:47
That's a steel line correct? Your only option is to braze it or find a used replacement. I've brazed several steel hydraulic lines over the years and I have never had one burst or leak again. Good Luck!
