Farmall M Low Oil Pressure
tractor man
09-02-2007 15:20:43
Lol guys this might seem dumb but have a farmall m and once warm it looses oil pressure quite a bit have checked it over and believe the crankshaft bearings to be the cause can i just install new bearings? can i get by doing that any help be great
Janicholson
09-02-2007 21:18:43
 Re: Farmall M Low Oil Pressure in reply to tractor man, 09-02-2007 15:20:43
Andy is on the track,
The replacement of rod bearings and mains can be done in frame. I would be looking at the oil pump first. Search for M oil pump cover in the box above for specifics. JimN
Andy Motteberg
09-02-2007 19:19:46
Use high quality engine oil. Check the oil pan and clean it and clean out the screen. Clean out the oil filter body and put in a new filter. While the pan is off, make sure there are no cracked or broken oil lines. If this does not work, try a different oil gauge, if not the gauge, it might be your oil pump or bearings.
