Wide tread A
liveoak415
09-02-2007 16:52:46
Would it be possible to install a right hand axle housing and axle on the left side of a Farmall A - thus making a wide tread A? Seems to me that the rear width would be about like a BN.
billde
09-02-2007 20:31:33
 Re: Wide tread A in reply to liveoak415, 09-02-2007 16:52:46
Not quite but close. You would need the left hand axle assembly from a BN to make the width the same as a BN [18 inches each side]. A regular B left hand assembly would be 4 inches too wide.
ScottyHOMEy
09-02-2007 17:19:07
I asked about that a few years back. What I was told was that it can be done, if you can find the longer differential shaft to get power to the left. Dimensions at the rear would be the same as a BN.
Distractions/challenges would include centering up the front axle to match, finding a B bolster if you decided to make it a narrow front, and the fact that the adapted A housing on the left wouldn't be cast and drilled to accept the same implements as either an A or a BN.
