Condensor farmall b
jeff lane
09-03-2007 13:39:27
Hey,
I believe i have a bad condensor. No spark. Would anyone know the specs on the condensor itself? I can test I just need the numbers.
Thanks,
jeff
JSharp
09-03-2007 20:55:53
 Re: Condensor farmall b in reply to jeff lane, 09-03-2007 13:39:27
Condensors have been about the same value for years because that's the value required to keep the points from pitting. That's it's prmary function.
You can remove it and you should have spark but you may have spark not just when the points open but also when they close. Spark will be erratic but you'll have spark provided everything else is in order.
If you don't have spark the things to check are straightforward. Make sure you have proper voltage at the coil. Make sure you have coil voltage at the points when they're open and zero volts at the points when they're closed. Make sure the points are clean. Make sure the condensor isn't shorted.
If all of the voltages are correct you should be able to manually open the points and get a spark from the coil. If not, the coil is bad.
jeff lane
09-03-2007 20:31:38
Thanks to all that responded. I have access to a 'fancy' tester however without the (I believe microfarad) spec I'm kinda stuck. So that leads me to my next question. If the capacitor is good, and I still don't get spark, any suggestions as to what it might be? I have a Case dealer fairly close so I'll get a new one. Also, I need a new float,dual, where would you suggest to get one (price minded). thanks again.
Gene-AL
09-03-2007 19:14:54
1958 Chev shop manual says 0.18 to 0.23 microfarad. I wonder if others in the Kettering era would be much different, tractors included. Voltage breakdown rating wasn't specified.
El Toro
09-03-2007 16:02:16
I would replace it and if the tractor starts you know its defective. Hal
Janicholson
09-03-2007 14:48:32
If it reads no resistance when first hooked up to a regular meter style Ohm meter, when turned either way it is toast. If it reads infinite resistance hooked either way it is toast. It should (when first attached) read a few ohms then taper to almost infinite ohms. This is the battery in the ohm meter charging the capacitor (that is what it is). This really does not dynamically check the breakdown voltage, or other higher frequency response of the condenser, but it can allow you to toss an open, or shorted one. A condenser checker is not a home product, and is rare because they are easier to replace than check. (condensers do go bad, but are the most over replaced for no reason element in the ign system) JimN
John T
09-03-2007 15:49:48
 Re: Condensor farmall b in reply to Janicholson, 09-03-2007 14:48:32
Jim, I know what youre saying buttttt ttt Ive expereinced the old fashioned "kickback test" (like youre thinkin) only works on analog ohm meters (for me at least so you actually observe the needle swing versus flashing numbers lol) and thennnnn nn its also necessary to use like the R x 10,000 scale to observe the initial charge up (where meter fitst swings towards 0 ohms as shes drawing charge up current) but then "kicks back" to infinity ohms (open circuit) once the condensor is charged.
I tell people to first set the meter on the R x 1 range and it should read infinity ohms PERIOD (or its a bad shorted condensor). NEXT to observe the "kickback" set it on the R x 10,000 range (discharged condensor) and when you attach the leads it ought to initially swing towards 0 ohms (likely never reach it however) but then kickback towards infinity ohms once shes charged up.
As you indicated, this ONLY tells if a condensor is BAD (like shorted or dont draw initial charge up current) but does not tell you if its good i.e. she can breakdown at higher voltage and just cuz it passes the ohm meter test dont really tell you if its good or not as a true capacitor checker which shows capacitance n leakege etc
Your thoughts please,,,,,can you use a digital meter n tell as much????? ????? Im NOT experienced with a fancy digital meter is why i ask, I prefer the old reliable Simpson 260 wooooo hooooo oo
Take care
John T
Janicholson
09-03-2007 21:12:25
 Re: Condensor farmall b in reply to John T, 09-03-2007 15:49:48
Dear John, The first sentence in my post (on my way to pick up my son's 4H garden tractor at the State fair. It intends a needle type meter. I agree with every thing you said. JimN
