706D Starter motor.
Redfan
09-03-2007 14:31:16
Can anyone tell me whether the starter off a 706D with 282 Diesel is the same as that used on a 766 or 1468? I have acces to one off a 1468 and was wondering if I could use it on the 706. Thanks.
K.B.-826
09-04-2007 16:16:39
 Re: 706D Starter motor. in reply to Redfan, 09-03-2007 14:31:16
It's very possible. Part numbers might not tell you much. Count the teeth on the drive, and measure the outside diameter of the drive. If they are the same on both starters, it should work. I'm pretty darn sure it will.
GA Dave
09-03-2007 19:38:07
Try www.caseih.com. See if any numbers match. Remember, those engineers had to keep changing part numbers for job security so if I were you I'd try it. Make sure the teeth mesh right to the flywheel. David.
