Alternator
1000yds
09-03-2007 15:35:39
I put a one wire alternator on my 300. My question is, should you get 12vdc to ground from both #1 & #2 terminals? One terminal is jumpered to the battery stud so it will obviously have 12vdc to ground. Should the other?
Thanks!
Gene-AL
09-03-2007 18:59:04
 Re: Alternator in reply to 1000yds, 09-03-2007 15:35:39
Should #1 terminal on a on-wire alternator have 12V?
Yes, 12V DC, when it is running, 0.0 Volts otherwise. The alternator has a diode rectifier trio that supplies 12V DC to #1 terminal when running (it also supplies the 12V to the internal field current regulator circuit).
#1 terminal can be connected through an 'idiot lamp' to an ignition-switched battery source, which will then indicate if the alternator is charging or not, and has the added benefit of starting alternator charging at lower RPM's. The lamp supplies a small battery current through the 'Idiot lamp' to the regulator circuit/alternator field to start the charging process. Then, as the alternater starts to charge, its internally generated 12V to #1 is about the same as the battery voltage and the lamp goes out since there is little or no voltage difference across the lamp. I've done this on a replacement GM-type 'one-wire' alternator on a tractor already equipped with an 'idiot lamp' and it worked just fine. Some 'one-wire' units may be different, I just don't know.
Note: A circuit added to #1 terminal must be switched on/off by the ignition switch, else it will drain the battery over time.
