Generator bracket Farmall A
history guy
09-03-2007 16:52:41
Where does the generator bracket mount to on a farmall A?
ScottyHOMEy
09-03-2007 17:17:51
 Re: Generator bracket Farmall A in reply to history guy, 09-03-2007 16:52:41
The weight of the generator itself is carried on a bracket bolted at the loewer left front of the crankcase.
If you're inquiring about the arm to secure it with belt tension, that arm mounts to a stud that runs through the upper hole on the water inlet at the lower frontof the engine. That inlet has two holes. Lower one takes a bolt, upper one slips over a stud that also anchors the bracket.
