Engine Oil for 460 Farmall
Eric Hellriegel
09-04-2007 07:00:39
What should I use for oil in my new 460? Thanks
sammy the RED
09-04-2007 21:23:02
 Re: Engine Oil for 460 Farmall in reply to Eric Hellriegel, 09-04-2007 07:00:39
Eric Hellriegel said: What should I use for oil in my new 460? Thanks
10w30 if use is light.
30w if used a lot.
15w40 if a diesel.
CNKS
09-04-2007 19:16:03
Depends on what your climate is. 15W-40 is a good compromise and can be used year around unless you run in a lot of below 0 weather. If you live in the south 30W is fine.
georgeky
09-04-2007 12:51:30
I use HD SAE 30 weight in all my Farmalls. Gas or diesel.
