130 Hydraulic pump
chad504
09-04-2007 08:26:45
My hydraulic pump on my 130 may be too far gone. I have it off, housing looks great, however the drive gear and shaft are worn badly, inside. Looks like the nut that holds on the drive gear came loose and the key began to wobble, for a long time. the drive shaft is worn, and looks off center, and the gear is just as bad. Can I replace those two pieces? it's a pesco pump. Also, will a pump from a super a/c/340 fit?
georgeky
09-04-2007 08:45:50
 Re: 130 Hydraulic pump in reply to chad504, 09-04-2007 08:26:45
Those parts are not available for those. New pumps are. One from any of the small Farmalls will work. SA,C,SC,100,130,140,130,140,200,230,240. Not sure about the 340, but it may work.
