how to tell what year and model from #'s
goodguys75
09-04-2007 18:18:35
just woundering how to find what year my tractors are ...looked at a number maching guide but none of the nubers were like mine. Im sure it is a simple task, but cant find anything. only numbers I was able to get were from the number plate on the tractor...FBK on the model M and FBH on the model H..... .
goodguys75
09-06-2007 08:22:29
 Re: how to tell what year and model from #'s in reply to goodguys75, 09-04-2007 18:18:35
thanks for the replies....will try soon, when i get a chance..andre
Bob M
09-05-2007 05:20:35
Find the date code on larger castings such as the engine block, head, transmission housing, axle housings, etc. These tell you the day/month/year each part was poured at the foundry.
USUALLY a tractor was assembled within a few weeks following the dates showing on it's larger castings. So generally you can discern your what year your tractor was built by checking date codes. (Presuming no large parts have been replaced that is...)
Date code format is like this: XX - YY - Z, where XX is the number of the month, YY is the day number, and Z is a letter code representing the year.
The year letter codes are:
A = 1931
B = 1932
C = 1933
etc...
U and W were both used in 1951 (and the letter V was skipped.)
X = 1952
Y = 1953
Z = 1954
A = 1955 (series starts over...)
arod
09-04-2007 20:14:56
serial numbers are found on a 3 inch tag riveted to the clutch housing on the farmalls.
