Farmall M
GA Dave
09-04-2007 18:28:00
I looked at a M today. SER # FBK2780?1. It leaks everywhere it can leak. I've got a call in to the owner. Talked to his wife and it runs. Really good sheet metal. Changed to 12 V.BAD tires on rear. Any ideas on worth? I didn't have my camera but in this area a M is not common. David.
Carden
09-05-2007 05:43:37
 Re: Farmall M in reply to GA Dave, 09-04-2007 18:28:00
Wow, I feel like a schmuck now. I spent $2000 on my M with a completely rebuilt motor (to Super M specs), rear axle leaks like a sieve (still trying to fix it), 12 V conversion, checked rears and still put another $850 in it for a Saginaw hitch (which I love by the way). It looks barely red anymore but fires up on the first crank and I still spent too much? Nothing special? Wanna buy it?
John M
09-05-2007 03:07:31
Ive got one that Id let go for 1500, but it needs tires, but the engine was rebuilt last year, and has a few other things changed. Youd have to haul it from SC. Ms are a dime a dozen here.(Oh the hydrulics will need fixed.)
GA Dave
09-04-2007 19:13:28
But Jim, it's a M. The owner said he had the head rebuilt. I didn't mention he said the hydraulics work, He thinks! I'll just have to check it out. It's a good looking greasy tractor. David.
HENRY E NC
09-04-2007 20:26:40
 Re: Farmall M in reply to GA Dave, 09-04-2007 19:13:28
Wheere in Ga are you looking for M's. I dont really think a leaking M with bad tires is worth more thanmaybe 1200. I bought two new tires and tubes for mine and they are expensive. !5.5's were cheaper than 12.8's two years ago.. There are a lot of M's in Tenn. if you are near there.
HENRY E NC
09-04-2007 20:26:28
CNKS
09-04-2007 19:18:21
Rebuilding the head only, without replacing the rings, etc, can actually increase oil consumption. IH built about 300000 M's. Good tractor but nothing special about it.
CNKS
09-04-2007 19:08:08
Jim is correct -- but even with good tires, an M is seldom worth $2000. $1200-$1500 is more like it, perhaps as low as $900 Jim suggests because of the leaks. I would look elsewhere.
GA Dave
09-04-2007 19:01:33
Just talked with the owner. Asking 2K. I'll try getting pics tomorrow. David.
hillbillyOH
09-05-2007 05:37:14
 Re: Farmall M in reply to GA Dave, 09-04-2007 19:01:33
That's way too expensive. Pass on it.
Janicholson
09-04-2007 19:01:09
900 would allow for the tires and leaks to make a 2000 tractor (not including labor) JimN
terryjd
09-04-2007 20:15:19
 Re: Farmall M in reply to Janicholson, 09-04-2007 19:01:09
To me $2000.00 seems real high by the time you put tires on it and fix the leaks. Having just had a head done for an M they are not cheap to have done. Still for that kind of money I would think you could get a M with good tires and in good running order.
Janicholson
09-05-2007 13:43:26
 Re: Farmall M in reply to terryjd, 09-04-2007 20:15:19
900 would be max to pay, The needed additional money would buy the tires and some of the leak repair material (no labor) when done, a person would have a 2000 tractor (or so) The price at 2000 is 1100 too high I was not very clear. The Modern view can mix and match posts when viewed on the old style format. I was the original poster, and did not know the asking price. JimN
