w-6 stuff,
kirk in ks,
09-05-2007 19:12:48
I need some pic's of a W-6 with the Hyd pump on it, if anyone has one that they have pic's of it,
Im gona redo mine, and I need reference to who redoes them, and how much It wouuld be,
plus,,, if there anyone that has the Hyd part's that go on the back of the tractor like the lg to small, type nipple's that connect to the back hose's, or the small bracket that hold's the nipple's to the front floor board on left side,and the lever valve,
Couuld some please tell me how to do the seal's on the back axle's as mine are bad,
and i only have one brake,( right side )?
Charles E. McNelly III
09-05-2007 20:01:00
 Re: w-6 stuff, in reply to kirk in ks,, 09-05-2007 19:12:48
Hi Kirk, Did you ever get around to fixing the rear main seal? Charles
kirk in ks,
09-05-2007 20:41:10
 Re: w-6 stuff, in reply to Charles E. McNelly III, 09-05-2007 20:01:00
Hi chuck, No I dint yet, i found out about the pump though, as i have to take it off, and then see if it can be redone, im hoping that it isnt scored on the inside, and that i can put a new seal in there and put it back together again,
then Ill get to the axle seal's and brake's and whatever else it need's before going back together,
stay in touch ok chuck take it easy ,
kirk,
