Farmall 140 Oil
ChrisNC140
09-05-2007 19:27:05
What are the capacities for oil, gear oil, hyd fluid, and antifreeze. Just bought a 63 and wanted to change everything first. (If i can figure out where everything is and how to check it) Also, anyone suggest a good service manual?
I have an I&T manual for shop service, but it is for major work. Thanks.
georgeky
09-05-2007 20:31:36
 Re: Farmall 140 Oil in reply to ChrisNC140, 09-05-2007 19:27:05
The IT manual is about as good as you can get. The engine will be Ok with SAE 30 weight motor oil It holds 5 quarts + the filter. The hydraulic unit holds just over 4 quarts of Hy-Tran or AW-32 Hydraulic oil. Non detergent 10, 20, 30 weight motor oil will also work well. Tranny holds 4 1/2 quarts of 90 weight gear oil. Final Drives hold 1 1/2 quarts of 90 weight. Cooling system will hold a little less than 4 gallon.
