Help with hooking up power steering on 400lpg
Rickyp
09-06-2007 11:08:58
I took the Behlen unit off of one 400 to put on another one. The parts tractor had a fitting that came out of the cast iron block on the left side of the dash. The one I have doesn"t have the place for the fitting. Can I install that by drilling a hole and tapping it? Can I just hook it up to one of the Hyd quadrants and run it that way? I could lock out the handle so it would pump continually. What do you think. Thanks, Ricky
SDE
09-06-2007 14:46:51
 Re: Help with hooking up power steering on 400lpg in reply to Rickyp, 09-06-2007 11:08:58
Could you swap the hydraulic control unit from the other tractor too? It is heavy. That is what I did with mine. The supply line hooked in to the unit from the bottom and not the side.
The manual will show the extra pieces you need in the control unit to get the P/S to work. I don't know if they came in all the units.
If the other tractor isn't going to have P/S any more, then if will not need those parts either.
SDE
georgeky
09-06-2007 16:32:51
 Re: Help with hooking up power steering on 400lpg in reply to SDE, 09-06-2007 14:46:51
Mine has the live line hooked in the regulater valve and return hooked at the bottom of resivoir.
georgeky
09-06-2007 12:44:40
Not real sure what you are talking about, but the pressure regulator valve must have the flow control valve from the other tractor to work, unless your tractor already has one. Likely it does not if it came without power steering from factory. All I ever seen have a plug on the side of the regulator valve block for this. If it doesn't have the flow control valve it won't work anyhow.
