tractor stands
AGR538
09-06-2007 16:11:38
Does anyone have pictures of homemade tractor stands for a Super M? I have to break mine apart to put in a clutch. Any help is appreciated.
Janicholson
09-07-2007 06:31:18
 Re: tractor stands in reply to AGR538, 09-06-2007 16:11:38
third party image
Here is a Nice design using regular iron shapes. Drill to fit rails as needed. JimN
terryjd
09-06-2007 20:36:30
Do you have to split a SM to change a clutch? Changed the clutch, pressure plate in our M last fall and could do it all through the access hole in the bottom of the tractor. Thought the SM was the same but don't know the SM very well so might be a bit different.
El Toro
09-06-2007 16:34:55
You may get a few ideas from this web site. Some of these guys that post on here have made their own. Hal
www.splittingstands.com/
Jim in Ma.
09-06-2007 16:56:48
 Re: tractor stands in reply to El Toro, 09-06-2007 16:34:55
I welded some pipe to an old car rim. then put a screw adjuster form erector type staging - works for me. Jim
