466 flywheel in 560
redsm
09-06-2007 18:09:37
If i put a DT466 engine in my 560, can i use the flywheel of the 466 or how will evreything bolt up
K.B.-826
09-06-2007 19:28:39
 Re: 466 flywheel in 560 in reply to redsm, 09-06-2007 18:09:37
You'd probably need a 966 or 986 flywheel. It should bolt up to your crank, and those two used the same clutch as 560.
Ry
09-06-2007 19:08:55
If you get that engine in there let me know how long your 560s rear end holds up! Yikes
wgatewood
09-06-2007 20:02:40
 Re: 466 flywheel in 560 in reply to Ry, 09-06-2007 19:08:55
there is a guy in penn who pulls a m with a dt 466 in it in the 6500 lb classes
