Hitachi Alternator
Tired 300 in Mn
09-06-2007 18:23:27
I just installed a Hitachi alternator on my H, but it doesn't charge. It's a NAPA rebuilt. I hooked it up as a negative ground one wire as per some instructions I read here some time ago, S connected to bat terminal & bat terminal to the right side of amp gauge. Left side of amp gauge goes to hot side of starter button. I made all my connections with the battery unhooked.I will probably bring the alternator back & have it checked. I'm guessing I did something wrong, I'm just not smart enough to know what it is. Thanks in advance for any suggestions. Sonny
BIG JOHN
09-06-2007 18:42:33
 Re: Hitachi Alternator in reply to Tired 300 in Mn, 09-06-2007 18:23:27
There is one instruction that you have left out. The "L" spade is used for the idiot light and also energizes the alternator. You need to run a hot wire to the "L" spade and you will be good to go. You can just run a switched hot wire to the "L" spade and you will have to turn it on for a short time each time you start the tractor. If you leave it on, after you have shut the tractor down it can run down the battery. I use a one way diode that only allows the juice to go one way and will not let a back feed. You can get these at Radio Shack for about $2.00 and you will not have to manual switch the wire.
GOOD LUCK
BIG JOHN
Daniel H.
09-06-2007 18:40:17
Look at this:
Link
If you have an AMMETER, it needs to go between the output of the alternator and the positive side of the battery. A VOLTMETER goes in parallel from the ignition switch to ground. Forget the one wire and do it like this:
Link
