Re: Super A Temperature Gauge
Daniel H.
09-06-2007 18:29:39
On the later tractors with a water pump, it is in the top water neck/thermostat housing. A Super C or 100/130/140 should have the correct water neck; not sure if it will match the radiator, as the Super A-1 and up used a taller radiator. I think with a water pump, you will need a t-stat or the engine will take a long time to come up to temp. Running an engine cold has problems, just as running it hot does. Also, I understand there is a difference in the head gasket.
