Farmall C - leak around brake/clutch pedal shaft - HELP
bbrinks
09-07-2007 04:50:04
Farmall C leaks around the Brake/clutch pedal shaft. I"m told there are no seals where the shaft exits the housing but how do you fix a leak then? Thanks
leon
09-08-2007 03:44:32
 Re: Farmall C - leak around brake/clutch pedal shaft - HELP in reply to bbrinks, 09-07-2007 04:50:04
I replaced the seals on mine and thought the shaft didn't look too badly worn so I put it back in, but it still leaked. I finally had to replace the shaft too to get her to dry up, so if your shaft shows much wear at the seals, I'd suggest you save yourself some time and put in a new shaft as well as seals.
chadd
09-07-2007 05:27:37
Whoever said that has never looked, or got it confused with another tractor. There is an oil seal on each side. You need to pull the shaft out to change them. The part number for the seal is 360076R92.
