1066 MC Valve
dwag
09-07-2007 16:19:46
Has anyone ever double gasket an MCV to get enough backlash at pump drive gear? Just installed TA, fired her up, and got a "squalling" noise. Dropped lower plate, and feels like very little backlash at gear. On original dissembly, gear was loose and pump shaft was worn.
ejr-IA.
09-07-2007 18:42:31
 Re: 1066 MC Valve in reply to dwag, 09-07-2007 16:19:46
They make different thickness gaskets for that reason.
dwag
09-08-2007 06:20:40
 Re: 1066 MC Valve in reply to ejr-IA., 09-07-2007 18:42:31
Got the thick gskt in.
dwag
09-08-2007 20:48:16
 Re: 1066 MC Valve in reply to dwag, 09-08-2007 06:20:40
ALSO, the question was... has anyone had to double gkst an MC valve to get backlash! Should have posted on Case board, would have gotten same Stupid replies.
K.B.-826
09-07-2007 17:01:32
Did you replace the pump gear? If so, did you get the correct gear? There were two different gear sets with different tooth angles, and they will squeal like crazy when mismatched.
dwag
09-07-2007 18:16:25
 Re: 1066 MC Valve in reply to K.B.-826, 09-07-2007 17:01:32
As far as I know, Steering pump gear is the same . PTO drive gear is different, which I double checked before installing. Thanks for your reply. Again, I don't have much backlash between steering pump gear and drive gear.
