H disk brakes
skk-big red fan
09-07-2007 20:27:04
When did disk brakes show up on a H? Was there a crossover period where you could order the conventional band or opt for disk?
john d
09-08-2007 06:12:07
 Re: H disk brakes in reply to skk-big red fan, 09-07-2007 20:27:04
If you mean the IH disk brakes, sometime close to the introduction of the Super H. There were also Lambert disk brakes on H and M tractors much earlier. I considered buying a '46 H that had them. They can be distinguised from the IH brakes by having only three bolts through the castings instead of four, and having the actuator rod coming out of the upper portion of the housing instead of the lower portion. I don't know if the Lambert brakes were only a dealer-installed item, or if some were factory installed.
jonnny2006
09-07-2007 21:24:27
late 52 right befor they started production super h. also the late model h's has the roller on the draw bar. they might even have put the c-164 in the h's at the end of the run, or some of the super h's got the c-152 i cant rembember what guy faye said in his letter series book.
