Farmall B - Sediment bowl leak
Dave H (MI)
09-08-2007 10:31:03
Just a bit of advice needed. Am I better to pull out the valve and silicon the threads like I did elsewhere or should I just try to tighten it down.
This is on the new sediment bowl and I am leery of too much tightening.
Dave H (MI)
09-08-2007 11:52:00
 Re: Farmall B - Sediment bowl leak in reply to Dave H (MI), 09-08-2007 10:31:03
Got it, I think. It was pretty loose so I pulled it out and put some of the liquid stuff on the threads and snugged it back down. No leaks so far. Thanks!
old
09-08-2007 11:26:06
Theres a gland packing in them that you tighten the nut down on and that stops the leak. Also over time that packing soaks up gas and expands some which will also stop the leak. It doesn't take much to stop that leak just a 1/4-1/2 turn most of the time is enough
Steven f/AZ
09-08-2007 10:39:26
I use teflon tape.
