wiring for lights on a 300U
Charlie M
09-08-2007 10:51:37
I want to put lights on my 300U and need to run the wiring. Can someone tell me what gauge wire I should use. Is there anyone making a wiring harness for either the front or rear lights?
GA Dave
09-08-2007 19:01:26
 Re: wiring for lights on a 300U in reply to Charlie M, 09-08-2007 10:51:37
Forgot to mention that once I left the instrument panel everything was put in the black plastic split wiring (stuff for lack of a better word) to the oil pressure source, temperature probe, lights, coil and even the + battery cable. Any auto parts and some hardware stores carry this. David.third party image
GA Dave
09-08-2007 18:42:21
I just looked at the wiring diagram for a 300 at www.caseih.com. Blow em up, print em out, whatever. They didn't give wire gauge but did give the color sometimes. 16 gauge is what I ran to the front and rear lights on my 240 U. Everything is fused at 15 amps on mine. 12 volt by the way. David.
Janicholson
09-08-2007 16:43:30
Jimer is good on the wire size, 12 would do on the supply with a 15 amp fuse in it. Caution, the light switch cannot stand any more than stock lights (in terms of total wattage. More than stock, and the little dimmer resistor becomes a light in its own way foe a brief moment, (heats up radically). JimN
Jimer
09-08-2007 11:58:21
10 gauge for power to the switch, then I think I have 14 gauge to the lights (I'd guess, 16 gauge would do it, I just over did everything).
