M Gas vs. Diesel
IndianaRed
09-09-2007 07:14:59
Was just browsing the Nebraska field test data, saw that a '51 M gas and diesel are rated the same horsepower. Was a little surprised, would've thought the diesel was stronger?
BOBM25
09-10-2007 08:55:04
 Re: M Gas vs. Diesel in reply to IndianaRed, 09-09-2007 07:14:59
I'm also pretty sure the diesel version had less hp than the gas, super or not. My experience is that the diesel will generally out pull the gas because it has more torque and from the factory the MD was heavier than the M gasser.
Daniel Jessup
10-10-2007 17:13:37
 Re: M Gas vs. Diesel in reply to BOBM25, 09-10-2007 08:55:04
the M diesels have the same horse power as the gas M"s and the super MD"s have the same as a gas super M
F-Dean
09-09-2007 16:36:19
Horsepower may not be the best measure of pulling power. The diesel M rear end is heavier and the axles are bigger in diameter. Torque may be a better measure. I would much rather plow with a diesel M than a gas M.
Harold H
09-10-2007 17:53:24
 Re: M Gas vs. Diesel in reply to F-Dean, 09-09-2007 16:36:19
F Dean,
The rear end is the same in the M and the MD.
Harold H
F-Dean said: (quoted from post at 16:36:19 09/09/07) Horsepower may not be the best measure of pulling power. The diesel M rear end is heavier and the axles are bigger in diameter. Torque may be a better measure. I would much rather plow with a diesel M than a gas M.
Nebraska Kirk
09-09-2007 11:47:35
Tractor test #328 in 1939, Farmall M (gas) 33 drawbar HP
Tractor test #368 in 1941, Farmall MD, 31 drawbar HP.
IndianaRed
09-09-2007 13:06:20
 Re: M Gas vs. Diesel in reply to Nebraska Kirk, 09-09-2007 11:47:35
third party image
This is what I was looking at this morning. bottom and third from the bottom, SM, SMD.
georgeky
09-09-2007 07:21:05
If anything it would be the other way around. Check out the 400 and 450.
IndianaRed
09-09-2007 07:24:53
 Re: M Gas vs. Diesel in reply to georgeky, 09-09-2007 07:21:05
That's what I thought too, but it's right there in black & white. Oh ya, they were both Supers.
http://tractortestlab.unl.edu/50-59.pdf
georgeky
09-09-2007 07:43:39
 Re: M Gas vs. Diesel in reply to IndianaRed, 09-09-2007 07:24:53
If they were Supers, they are quite rare, None were built in 51
IaGary
09-09-2007 07:20:16
In most models the diesel verses gas, the gas is higher HP.
But the economy of the diesel per horse power was better than the gas.
Gary
terryjd
09-09-2007 21:21:25
 Re: M Gas vs. Diesel in reply to IaGary, 09-09-2007 07:20:16
When at the fairs that had antique tractor pulls we went to a guy had an MD and it would pull in the 30 to 35hp class, we would pull in the 36 to 40 hp class with the gas M. The book the people that ran the pulls showed the MD at just under 35 hp.
