Farmall M and W-6
Chris Klein
09-09-2007 07:31:37
I see it looks like the M and the W-6 use the same engine. I am looking for information on interchangability of the rest of the tractor. I have an M and have found 2 W-6's There would be just about enough to build one W-6 with alot of extras left over. I was woundering if anyone can tell me what all will also work on the M too.
Thanks for any info Chris
Yugrotcart
09-09-2007 08:06:59
 Re: Farmall M and W-6 in reply to Chris Klein, 09-09-2007 07:31:37
Chris,
From my understanding, the M and W6 engines and rads are interchangable. The M rad does have a hole for the steering shaft, but will fit the W6. Pretty much everthing else is different.
Paul
Charles E. McNelly III
09-09-2007 19:14:00
 Re: Farmall M and W-6 in reply to Yugrotcart, 09-09-2007 08:06:59
Engine, Clutch, and tranny all the same with the exception the axles are different and the W-6 has a faster ring gear then the M. Good Luck.
Charles
