560 oil leak lower pulley of fan belt
Tom Lee
09-09-2007 19:04:47
Just purchase a 560 and just got it home and found a little oil leak around the lower pulley of fan belt on engine....Is this something that is costly to repair or does it need to be fixed or can I just leave it and add a little oil now and then..... ...just a little drip now and then....just using the tractor to move snow in the winter time....
glennster
09-10-2007 08:07:32
 Re: 560 oil leak lower pulley of fan belt in reply to Tom Lee, 09-09-2007 19:04:47
sounds like the lower crankshaft pulley seal is leaking. pretty sure you need to remove the front bolster with eth front wheels and radiator ect to get at the lower pulley. use a gear puller or bearing splitter to get the pulley off, then you will see the seal. seal should pop right out, and new one drives in. check the pulley surface to see if there is a groove worn in it from the seal, if so, you can get a speedy sleeve from berry bearing, and install that, and you are good to go.
