arcing at solenoid
mwilke
09-10-2007 10:11:54
I bought a SH with a 12 volt system on it. When I start it there is considerabe arcing at the solenoid while starting. It seems to go away when tractor is running. Can anyone give an idea what I have to do to fix it? Thanks
Mike
mwilke
09-11-2007 05:08:48
 Re: arcing at solenoid in reply to mwilke, 09-10-2007 10:11:54
Thank you all for the info. The connection at the point of the arcing was not tight. I found shortly after I posted the note. I have not tried to start tractor yet. Thanks again.
Mike
230,H,M
09-10-2007 17:58:00
I had the same problem. It was caused by a bad solenoid. Replaced it and problem disappeared.
John T
09-10-2007 13:21:39
That arcing connection no longer exists once the solenoid is no longer energized. I agree with the other gents, sounds like a loose or carboned up or otherwise poor connection which hopefully removal n cleaning n wire brushing of alllll components n terminals n studs etc may cure UNLESS its a poor cable end crimp and the carbon n arcing is taking place where you cant remove n fix it like under the crimp between it n the cable grrrrr r?????
John T
old
09-10-2007 11:43:43
As Rusty says. Arcing like that can only be from loose connections or a bad soliniod
RustyFarmall
09-10-2007 11:14:19
Clean and tighten ALL electrical connections. If the arcing is coming from inside the solenoid, replace it.
