farmall Hmax pull
Pat-CT
09-11-2007 16:43:38
i am not looking to win but im hoping to pull the sleed a little ways down the track to not look like a idiot with the h in first gear pull 4500 a little ways i think its a little much but its the lowest weight class
Pat-CT
09-11-2007 18:15:22
 Re: farmall Hmax pull in reply to Pat-CT, 09-11-2007 16:43:38
andrew z im looking at the durham fair pull coming up
Andrew Z
09-11-2007 18:25:48
 Re: farmall Hmax pull in reply to Pat-CT, 09-11-2007 18:15:22
Well if your loooking to pull stone boat we pull a good amount of weight there and is more of a "power pit" however there we have 4000# class that you can get your H into. I pull my H in that class at a few pulls and i can stay with them. My H is 100% stock with nothing done to it. If you take those weights off you should be right there! I have the hydor pump still and belt pully still on mine and i make it. My father pulls his Super H in 4500# but its like two times the tractor. and I pull a Allis B in 2500#. If you want to pull the transfere if your tractor is stock then it will be alittle lite on power. It all depends on what you want to do, either way its good to see a new puller out there!
My Email is open if you have more Q's Thanks
Andrew
Andrew Z
09-11-2007 17:55:49
Are you looking to pull with Ct (transfer sled) state or antique (stone boat) ? I pull both if you have Q's about these let me know, more than happy to help.
Andrew
Pat-CT
09-11-2007 17:11:49
i have 2 sets of wheel weights but will need aditional weight ... any ideas my idea was to make a template of the top transmission cover in the shape of a u and cut a huge chunk of metal to that size
Pat-CT
09-11-2007 16:58:24
i think its tractor weight but im not sure at all i have no clue how much weight they will be putting on the sled if thats it
Pat-CT
09-11-2007 16:56:58
this is my first time pulling im looking a the fairs rool book and it says 4500lb stock then says all the tractors must be stock with no chassis modifactions stock rpm etc this is the lowest stock class so i dont know what it goes by but i have seen h's pull here before im not sure how it will do tho
georgeky
09-11-2007 17:03:31
 Re: farmall Hmax pull in reply to Pat-CT, 09-11-2007 16:56:58
Thats what I thought. I have pulled against H's in 5000 pound classes and they should have been watching. The M's and A JD's walk off with them. If yours don't have fluid or weights some weights will need to be added to get to 4500. The C and SC will give it a run for the money.
Pete76NY
09-11-2007 16:47:12
Weight her up...at #4500 it'll be too light and the Cs and Super C's will be at their optimum pulling weight, and will eat ya alive. #5000-#5500 is best unless ya run into a real strong Super C, or a Super H.
supermpuller
09-11-2007 18:32:27
 Re: farmall Hmax pull in reply to Pete76NY, 09-11-2007 16:47:12
Where I come from the M, SM , S88 olivers and DC Cases will eat him up at 5,000 weight and over.
georgeky
09-11-2007 19:42:33
 Re: farmall Hmax pull in reply to supermpuller, 09-11-2007 18:32:27
Me too. The H just won't cut it.
georgeky
09-11-2007 16:46:41
Pat, are you sure that isn't for 4500 pound tractors instead of 4500 pound sled? Most H's don't have hardly enough power for the sled.
