Order Farmall Cub Parts Online
Farmall Cub does not start
lorfarm
09-12-2007 09:15:50
Coil has no spark. Done replaced with a good coil, but still no spark. Current got through to the coil from the switch. Any idea is greatly appreciated. Thanks
john *.?-!.* cub owner
09-13-2007 19:34:19
 Re: Farmall Cub does not start in reply to georgeky, 09-12-2007 09:15:50
use voltemeter or test light . should have voltage to switch side of coil, and on the distributor side of coil you should see voltage/no voltage as the points open and close. If no voltage, bad coil, shorted condenser, etc.
El Toro
09-12-2007 09:41:08
 Re: Farmall Cub does not start in reply to lorfarm, 09-12-2007 09:15:50
I would replace the condenser and clean the points. You need to check that switch if voltage is being fed to the coil with the switch in the off position. I hope this is a distributor that you have. Hal
Andy Motteberg
09-12-2007 09:18:47
Magneto or Distributor?
Did you wire the coil correctly? If not, the coil will burn out.
lorfarm
09-13-2007 13:49:01
 Re: Farmall Cub does not start in reply to Andy Motteberg, 09-12-2007 09:18:47
Yes, I did have the wires connected right. I also have another cub that is working. I placed the coil on the bad cub to the working cub and it is working. I placed the coil that was on the working cub to the bad cub, and no spark. I'm out of ideas.
Andy Motteberg
09-13-2007 14:21:37
 Re: Farmall Cub does not start in reply to lorfarm, 09-13-2007 13:49:01
lorfarm said: (quoted from post at 13:49:01 09/13/07) Yes, I did have the wires connected right. I also have another cub that is working. I placed the coil on the bad cub to the working cub and it is working. I placed the coil that was on the working cub to the bad cub, and no spark. I'm out of ideas.
If the coil works and is wired right, you have a different problem. Is this a distributor or a magneto? You should put in a new ignition tune up kit, the are not expensive and should include new points, condenser, rotor and points setting gauge.
