Grill
Nifty 350
09-12-2007 09:39:22
The grill on my tractor does not have the screen in it, but I want to add it. Problem is the little tabs that hold it are broke off due to rust.
Any suggestions?
BOBM25
09-13-2007 13:20:48
 Re: Grill in reply to Nifty 350, 09-12-2007 09:39:22
I just put a new screen in my MTA grill. It sounds like you are talking about the little tabs that are actually on the grill piece, not the clips that come with the screen. 2 of mine broke when I tried to bend them back down also. I just used some small wire and looped it around the pieces that the clips were originally spotwelded to, then twisted them tight on the back with a linesman pliers. It worked great and you can't see them from the front. OEM also sells the clips and screen. Don't mess with the clips though, they are a huge rip-off and you need a spotwelder to put them on.
Genos
09-12-2007 18:58:47
I Have Installed Some Screens On Farmalls & When Clips Are Broken I Used Globs Of JB Weld On Back Of Grill To Hold Screen & Put A Weight On It Till It Dried & Have Never Had One Come Loose.
