230 snow plow
Schlijas
09-12-2007 12:19:56
Did they make a snow plow for a 230 with wide front? If so, does anyone know where a person could find one? What other snow plow models would work with out alot of work? Thanks for the help.
homard
09-13-2007 07:03:25
 Re: 230 snow plow in reply to Schlijas, 09-12-2007 12:19:56
Before you buy a blade, check to see what kind of hydraulics you have on the 230. A lot of blades are designed for "Touch Control" hydraulics (look for the rocker arms below the gas tank).
"Touch Control" is the same type of hydraulics found on the Super C. The 230 could have either "Touch Control" OR "Hydra Touch" hydraulics (or nothing). If it has "Hydra Touch" there will be NO rocker arms under the gas tank and maybe a set of auxiliary hydraulic service taps on the left side under the gas tank (note not all 230's with "Hydra Touch" have the aux. svc's.)
Knowing what type of hydraulic system you have will determine how you will mount and control the blade positioning
georgeky
09-12-2007 13:12:24
Yep, they come up on ebay quite often. Must have the center lift bracket too for a front mount. Also fast hitch rear blades available sometines.
