F20 overdrive input seal
IndianaMike
09-13-2007 08:09:00
Anyone know where I can get a seal for the input to an overdrive gear? Mine leaks like a sieve. It is the same diameter as the coupler yoke and has a spring inside it to hold tension on the yoke.
gene bender
09-13-2007 19:18:04
 Re: F20 overdrive input seal in reply to IndianaMike, 09-13-2007 08:09:00
Take the old one out then go to nearest NAPA,CAR QUEST AUTO ZONE and they can get one for you. Measurements can be taken off old one and from thereon its easy.
JohnG(TX)
09-13-2007 10:33:21
I recently bought a new one for my Regular road box. I think it is a Behlen box. I took the front plate and yoke to a bearing & seal shop. they measured the ID of the plate and the OD of the yoke and came up with a good seal. I have not finished the tractor, so I don't know how well it will work over time, but it looked like a good fix. The new seal was not the deep lip seal like the original, just a standard lip seal. Some of those boxes can be a bear to get apart. On some, the yoke pulls off a splined shaft, on others it unscrews.
