404 3PT lower link dimensions...
JSharp
09-13-2007 09:24:31
Anyone with a 404 could you do me a huge favor? I need the dimensions of the 3 point lower links. Center to center of the pivot points, and also to the lift point and limiter chain attachment hole.
The lower links on my 404 are trashed and after looking at them, I'm not even sure they're the proper ones. If I have the dimensions I should be able to tell...
And thanks in advance!
JSharp
09-17-2007 09:32:35
 Re: 404 3PT lower link dimensions... in reply to JSharp, 09-13-2007 09:24:31
I got some new arms ordered that will work with slight modification. But here's one other thing I noticed. The mounting pins on the tractor are not 7/8" as I'd expect but right around .810" That's going to leave a standard 7/8" arm end too sloppy on the mounts without some sort of sleeve. I guess I'll figure that out once I get the arms...
JSharp
09-14-2007 09:45:01
 Re: 404 3PT lower link dimensions... in reply to ericlb, 09-13-2007 09:24:31
Thanks Hugh!
That'll get me much closer. Mine are too long I can see and the geometry looks wrong. Looks like someone fitted some old Ford arms to my 404...
HughB
09-14-2007 09:25:00
I think it should be as follows. Center to center at the pivot points 31 inches.
from the tractor pivot point to the chain attachment 17 inches.
from the tractor pivot point to the lift attachment 20 inches.
This could be off a fraction or so as the arm is still hooked to the tractor.
