Order Farmall Cub Parts Online
Cub Hydraulics
Richard M. Clar
09-13-2007 13:19:04
Hello All
I have a 1948 Cub with touch control hydraulics. When I have it in the up position I get constant "surging". Any suggestions? Other then SAE10, is there any other oil that is suitable?
Thanks
john *.?-!.* cub owner
09-13-2007 19:30:16
 Re: Cub Hydraulics in reply to Charles E. McNelly III, 09-13-2007 13:19:04
it probably needs cleaned. here is a link to an online manual for the touch control wiht a trouble shooting section listing your problem.
Link
Jim in Ma.
09-13-2007 17:53:25
 Re: Cub Hydraulics in reply to Richard M. Clarke, 09-13-2007 13:19:04
it may need a new head gasket - if you do change it make sure you keep everything clean when you put it back together.
Always use Hitran in it = from Case-IH.
El Toro
09-13-2007 14:35:31
You can use Hytran or Hygard. Hal
Richard M. Clarke
09-19-2007 15:23:20
 Re: Cub Hydraulics in reply to El Toro, 09-13-2007 14:35:31
Thank you all. I just ordered a rebuild kit. I imagine 50 year old o-rings and gaskets could use some help. The head gasket was torn towards the center. Now I hope that I can remember where everything goes.
El Toro
09-19-2007 16:01:34
 Re: Cub Hydraulics in reply to Richard M. Clarke, 09-19-2007 15:23:20
I have a parts breakdown on the Pesco pump. If you think you will need it, I can post it or email it.
Hal
