URGENT - PESCO Hydro Pump help
chad504
09-13-2007 13:37:32
I think I've got this thing ready to go, except I'm an idiot. I need to know what side of the pressure plate faces the gears. I think it's the side with the "fingers" then I assume the o rings go last, in front of the plate, towards the front of the case.
El Toro
09-13-2007 14:32:58
 Re: URGENT - PESCO Hydro Pump help in reply to chad504, 09-13-2007 13:37:32
third party image
Here's a Pesco pump parts breakdown. Hal
Janicholson
09-13-2007 14:10:19
The plate probably has a pattern of wear marks in the surface of the plate. They may be so small that it will take direct sunlight to see them. If the plate was surfaced, how was it done with the prongs sticking out, would that help decide? THe caseih.com website does not show a disassembled pump (though it should) JimN
