farmall m hood
chad 9999
09-14-2007 14:14:48
looking for a hood for my farmall m i have three m tractors but all the hoods are in need of a major overhaul. new or good used any info would be of great help
MN Rick
09-15-2007 09:36:45
 Re: farmall m hood in reply to chad 9999, 09-14-2007 14:14:48
Got a couple decent ones.....e-mail me.....Thanks
RustyFarmall
09-15-2007 05:58:56
I really doubt that you will find a new one unless it would happen to be new old stock. They are no longer being made, plus, it is not likely that you will find a used hood that won't need some kind of work either. Stress cracks from vibration can be brazed or welded and made to be invisible, and the hole around the exhaust pipe can also be patched. Find a good body and fender shop, or start learning the skills yourself. It's kinda fun once you get the hang of it.
chad 9999
09-15-2007 06:42:00
 Re: farmall m hood in reply to RustyFarmall, 09-15-2007 05:58:56
we just finished restoring dads 52 john deere g and it had alot of work done to the hood but the farmall m hood like you said suffers alot from vibration and stress a little concerned about the filler not lasting I have a deere 50 that needs only to be painted but I love those m tractors plus it has power steering
Janicholson
09-14-2007 14:27:17
Just to assist, not flame. The best bet is to use the add section to the left. Though some times requests and for sales get answered here, the discussion is for topics, not needs for parts. JimN
chad 9999
09-14-2007 15:26:11
 Re: farmall m hood in reply to Janicholson, 09-14-2007 14:27:17
The need for a hood is a topic i was needing to discuss, on the discussion forums, if you folks would assist and not insist it might be more helpful if you dont know the answer to the question dont bother with it and dont be flamed by this; your comment did not flame me; it assisted me to think of the statement..... ..
jonnny2006
09-14-2007 21:21:06
 Re: farmall m hood in reply to chad 9999, 09-14-2007 15:26:11
Chad
the guys in here can be "clicky" so if your in there click you can pretty much say what you want and others will help you out. One day i put some pictures of some nice tractors that i came across and some others gave me alot of slac for it. don't worry about it. These guys on here are some of the best people i know, and are very helpful.
I know where there are 2 M hoods sitting right now. I'm in s.e. mn. where are you located?
chad 9999
09-15-2007 00:38:26
 Re: farmall m hood in reply to jonnny2006, 09-14-2007 21:21:06
just southwest of louisville ky
NDS
09-15-2007 06:06:59
 Re: farmall m hood in reply to chad 9999, 09-15-2007 00:38:26
If you are ever in South Central TN Campbells Tractor Parts in Lawrenceburg will most likely have one last time I was there they had several good ones.
