Farmall M engine
Patrick Hancock
09-14-2007 16:38:33
Looking for good engine, assembled, for Farmall M.
Unless you want to buy mine for your own restoration.
ChadS
09-15-2007 06:00:42
 Re: Farmall M engine in reply to Patrick Hancock, 09-14-2007 16:38:33
I have a long block for a M. Took it from a running tractor. Head is on it, no accesories, No rocker arms, valve cover, oil pan or oil pump, carb intake, distributor, governor.
Thie engine ran good, carried good oil pressure, had a t i s c o engine kit installed a few years ago. the long block is still all together, wrapped up in plastic.
Or, I have a M block, bored for 450 sleeves. takes it out to 281 ci in M clothes.
Dave, I may know where there is a good short block for a SM-450,, let me check see if its still there!! wasnt stuck, probably needs to be overhauled. was in a early 400 in a puller, dressed up like a SMTA,,,, they quit pulling years ago, and the carcass is sitting out in a parking lot! Had a new heavy duty TA, pressed steel rims, but, now its parts. Last I heard, could buy the whole tractor for 1350,,, which is a 400 LP,,,,, So it came with LP hood and parts for the 400. Just thought Id tell ya bout it,,, I know it was still there, and if I could, I would have gotten it,,, but I figured,,, they might get back into pulling, or fix it back up,,,, but, never had, and said, never will,,, soo,,, FYI....
Chads3@hotmail.com see ya! ChadS
Dave S.
09-14-2007 18:38:04
Stauffer Salvage had a good one a couple of months ago, I had thought about buying to put in a super M but decided to wait for a super engine. They said it run good. Ph#785-966-2739
DCW
09-14-2007 18:09:45
Where do you live?
Patrick Hancock
09-15-2007 07:18:38
 Re: Farmall M engine in reply to DCW, 09-14-2007 18:09:45
New York State, near Poughkeepsie, between Albany and New York City.
