international 3414 3 pt hitch hyraulic problem
keith smith
09-14-2007 17:04:41
my 3 pt hitch stopped working, not sure if problem is in pump or control valves checked
oil under seat by pulling cover. looked good
Seems to have good pressure coming from
The pump And going to the control valves
i don’t have any way to check actual pressure
they wont go up at all
Fromjb2
09-15-2007 19:03:34
 Re: international 3414 3 pt hitch hyraulic problem in reply to keith smith, 09-14-2007 17:04:41
Hi Keith, could be either a clogged suction filter or orifice filter. Suction filter is on end of suction line (large line) that goes into hydraulic reservoir casting on lower right by front of seat. Orifice filter is behind big plug on left hand front of seat on hydraulic housing.
Did some one accidentally close the 3 pt/remove control tap on the casting in front of the seat?
Make sure the draft control lever is forward.
Hope this helps
JimB
keith smith
09-16-2007 17:37:46
 Re: international 3414 3 pt hitch hyraulic problem in reply to Fromjb2, 09-15-2007 19:03:34
thanks for the help jimb
i checked the filter at the orifice and it checked out clean, started pulling out the
suction filter but stopped because i didnt have the time today. i noticed today that it looks like air bubbles coming from the plate under the
seat. looks like i will need to pick up a gasket
for the plate.
thanks again
