farmall a carb
tyler cohrs
09-15-2007 15:50:53
I have Zenith carb an my A and when running it needs half choke to run smooth. It also drips from the bottom of the carb when its not running. should I put one of those Main jet adjusters on it? thanls
Wayne in MN
09-15-2007 20:09:53
 Re: farmall a carb in reply to tyler cohrs, 09-15-2007 15:50:53
The tractor ran just fine when new without an adjustable main jet. Your carb needs cleaning and check for fuel line blockage. The drip is indicating the needle & seat are leaking.
Dave H (MI)
09-15-2007 16:35:52
I thought the main jet adjustment was only for tractors running on distillate/kerosene and that you adjusted the jet depending on the type of fuel you were using. That is what I got from the manual. I have been told about 10 times in the last month to shut off my gas if I am going to leave the tractor for more than 10 minutes (see Jim? I do pay attention!) The choke thing is over my head.
Janicholson
09-15-2007 20:55:33
 Re: farmall a carb in reply to Dave H (MI), 09-15-2007 16:35:52
I knew it, I just knew it. No pulling the wool over those eyes. JimN:-)
