IH660D Trans./Hydr. Fluid Capacity
srodster
09-15-2007 19:13:23
Can someone let me know how much trans./hydr. fluid should go in a IH660D tractor?? Also, where the heck is the dipstick or check plug??
Thanks for any assistance.
Ted in NE
09-16-2007 10:34:18
 Re: IH660D Trans./Hydr. Fluid Capacity in reply to srodster, 09-15-2007 19:13:23
Be sure & change the oil in the rear planetarys, use Hy-Tran same as trans & rear end.
billde
09-16-2007 06:19:23
It will take about 17 gallons if you have it completely drained. There is a fill level plug on the left side of the transmission. Don't forget to change the filters.
srodster
09-16-2007 09:25:30
 Re: IH660D Trans./Hydr. Fluid Capacity in reply to billde, 09-16-2007 06:19:23
OK, thanks. I'm assuming there is only one filter on the right side that feeds the hydraulic pump on the left.
billde
09-16-2007 10:46:42
 Re: IH660D Trans./Hydr. Fluid Capacity in reply to srodster, 09-16-2007 09:25:30
Depending on what year the tractor is it will be either one oblong or two donuts on the right side.
srodster
09-23-2007 05:06:31
 Re: IH660D Trans./Hydr. Fluid Capacity in reply to billde, 09-16-2007 10:46:42
billde, can you help me with another question? Can't find my parts manual and trying to ID the correct seal that goes around the brake shaft on the left side of engine, (same one the clutch slides over)my seal is leaking and want to get the right one.
